A join to an instance of PM is failing over. PM is slave on this join. There will be a pause in OSPF processing until the join is reconnected to a backup instance of the master on this join.
Investigate why the original instance failed over. If the problem persists then please contact support.
Warning
%p1% A fault tolerance procedure has been initiated. Diagnostic information for support: Master index = %p2%
| Name | Type |
| p1 | String |
| p2 | uInt32 |
